Best injector for my setup?
918 views 4 replies 4 participants last post by  burton3
I'm running a set off Bosch 300+hp injectors right now. Yes I know I'm crazy for running such a big injector for my truck the only reason I am is because I got an amazing deal on them. I am running a silver bullet 66 at the moment but I plan to run a s480 compound setup with it in the very near future. What would be the best size injector to run with a 66/s480 setup. I have a hotrod vp44, bigger cross over tubes, a fass 165gph, and a quad adrenaline. Thanks for any help.
#2 ·
Ya thats alot of fuel but with a 66 over a 480 your gona move a ton of air if i was you i would leave it alone thro the 480 on and go from there see how it works if it hot and to smoky then maybe drop to a 250 or 220 but i dont think i would go below the 200's tho save the money buu tje twin kit and see what you get. It should be a monster... I bet its a monster now
A vp will never come close to the full capabilities of a 66/480 combo with a 300+ injector. In theory that set up should be good for 800-900hp+ but id be surprised if you get to 650-700hp range even with a hotrod vp. Twin it and see what it does and go from there.
#5 ·
Well it's defiantly over fueling. I'm putting DDP 200hp injectors when I do twins. They started out as 7x.016's I believe but they've been honed.
